Unable to open any report in AX - error -No connection could be made because the target machine actively refused it
While trying to open any report in AX I am facing this error:
"No connection could be made because the target machine actively refused it "192.XXX.X.XX.8201"
and I have double checked that the windows firewall is turned off and in the report serevr settings of AX , it is pointing to the right report server (and all the details are correct, becuse when I calidated the settings , it gave me a success message).
What I identified is the port number I see in the error message is 8201 while AX config file's wsdl port number is 8101.
I suspect this could be the issue..
But I am not sure how to and where to change this port number to pick 8101 instead of 8201.
Can anyone help me out here please.
Thanks in advance
Archie
  • Have you tried running the report from the reporting server site directly? Are you able to open it from there or not?
  • In reply to Krupa:
    Hi krupa,
    Thanks for looking into the issue. Yes, I have tried opening with both report manager URL and Web service URL and all the reports (whichever report I open ) display the same error message 'The 'AX_CompanyName' parameter is missing a value ', which I'm afraid is not the issue.
    Best
    Archana
  • In reply to archana:
    Hey what is the value for "permission set name" on the Report_Expressions_Default_Permissions in the rssrvpolicy.config file set to ? Probably it is set as "Execution", if it is then change it to "FullTrust"
    <CodeGroup class=”UnionCodeGroup” version=”1″ PermissionSetName=”FullTrust” Name=”Report_Expressions_Default_Permissions” Description=”This code group grants default permissions for code in report expressions and Code element. “>
  • In reply to Venkat Chaitanya Kanumukula:
    Also try redeploying "BIServices" from AOT.
  • Hi Archana,
    Could you please let us know if:
    1. You are able to deploy any report from AOT?
    2. Was SSRS DB reinstalled/ restored from any other location/ backup?
    3. Was SSRS reconfigured to connect to a different server?
    4. Is there any other IIS site configured with the same port?
    I had received this error before and there could be many reasons behind this. I would thoroughly inspect the configuration, settings and setup.
  • Could you please Compile CIL?
  • In reply to Turgut:
    Deploying any AIF services from AOT will start CIL compilations, So my above suggestion of redeploying "BIServices" covers that part. Probably the issue might have been resolved.
    Archanae , if your problem is resolved --please close this thread.
Related
Recommended
