How to import the list of employees
Hi
in my excel sheet fields like are FisrtName,PersonalNumber,LegalEntity,EmployeementType,HCM_Employeement_ValidFrom
How to import the data from excel to ax table
  • In reply to Gopinath M:
    Thanks gopi,
    I am not able to open that above link here please share the code..
  • In reply to AKumar:
     Importing Data from Excel Sheet to Table in AX 2012
    static void Esh_ImporttoExcelProductType(Args _args)
    SysExcelApplication application;
    SysExcelWorkbooks workbooks;
    SysExcelWorkbook workbook;
    SysExcelWorksheets worksheets;
    SysExcelWorksheet worksheet;
    SysExcelCells cells;
    COMVariantType type;
    Name name;
    FileName filename;
    Esh_SampleTable esh_sampletable; //Declaring Table Name
    int row;
    str _productTypeId;
    str _productType;
    str _description;
    application = SysExcelApplication::construct();
    workbooks = application.workbooks();
    //specify the file path that you want to read
    filename ='D:\\Test.xlsx'; //ExcelSheet File Name
    try
    workbooks.open(filename);
    catch (Exception::Error)
    throw error('File cannot be opened');
    workbook = workbooks.item(1);
    worksheets = workbook.worksheets();
    worksheet = worksheets.itemFromNum(1); //Here 1 is the worksheet Number
    cells = worksheet.cells();
    do
    row++;
    _productTypeId = any2str(cells.item(row, 1).value().toString());
    _productType = cells.item(row, 2).value().bStr();
    _description = cells.item(row, 3).value().bStr();
    esh_sampletable.ID = _productTypeId;
    esh_sampletable.Type = _productType;
    esh_sampletable.Description = _description;
    esh_sampletable.insert();
    type = cells.item(row+1, 1).value().variantType();
    while (type != COMVariantType::VT_EMPTY);
    application.quit();
    info("Data is Imported");
  • Why cannot you use data import export framework?
    Ok Thanks gopi
  • Can you try using Excel addins? This makes your job easier .
  • In reply to Anitha.E:
    Hi thanks for reply
    How to use Excel addins can you please tell me the steps
    You can also use DIXF, see this Blog
  • In reply to Kranthi:
    Hi kranthi,
    But here not working DIXF.
    Fields are " DirPersonName.FirstName,HcmWorker.PersonnelNumber, HcmWorker.workerRelationType(),LegalEntity".
    AKumar
    You don't want to use it (or) is it not working?
    it's not working kranthi.
    Can you explain the issue you have?
    Basics setups and overview of Excel addins are given in the below blog.
    anithasantosh.wordpress.com/.../
    hI,
    is there any module called DIXF in ur AX??
    HI gopi/Kranthi/Anitha Thank you so much for giving reply
    This issue has be done
    static void EmpImport(Args _args)
    COMVariantType comtype;
    HcmWorker hcmWorker;
    HcmEmployment hcmEmployment;
    DirPerson dirPerson1;
    DirPersonName dirPersonName;
    CompanyInfo companyInfo;
    HcmPersonnelNumberId personnelNumber;
    utcDateTime validFrom;
    HcmEmploymentType employmentType;
    Name firstName, companyName;
    int insertcount=0;
    int row = 1;
    Dialog dialog;
    DialogField fileName;
    str COMVariant2Str(COMVariant _cv, int _decimals = 0,int _characters = 0,int _separator1 = 0,int _separator2 = 0)
    switch(_cv.variantType())
    case (COMVariantType::VT_BSTR):
    return _cv.bStr();
    case (COMVariantType::VT_R4):
    return num2str(_cv.float(),_characters,_decimals, _separator1,_separator2);
    case (COMVariantType::VT_R8):
    return num2str(_cv.double(),_characters,_decimals,_separator1,_separator2);
    case (COMVariantType::VT_DECIMAL):
    return num2str(_cv.decimal(),_characters,_decimals, _separator1, _separator2);
    case (COMVariantType::VT_DATE):
    return date2str(_cv.date(),123,2,1,2, 1,4);
    case (COMVariantType::VT_EMPTY):
    return "";
    default:
    throw error(strfmt("@SYS26908",_cv.variantType()));
    return "";
    dialog = new Dialog();
    dialog.caption("Select File");
    fileName = dialog.addField(extendedTypeStr(FilenameOpen));
    dialog.run();
    try
    workbooks.open(fileName.value());
    catch
    throw error("File cannot be opened");
    do
    row++;
    personnelNumber = COMVariant2Str(cells.item(row,2).value());
    firstName = cells.item(row, 1).value().bStr();
    employmentType = str2enum(employmentType, cells.item(row, 3).value().bStr());
    validFrom = DateTimeUtil::newDateTime(cells.item(row, 4).value().date(), 0);
    companyName = cells.item(row, 5).value().bStr();
    try
    ttsbegin;
    select hcmworker where hcmWorker.PersonnelNumber == personnelNumber;
    if(!hcmworker)
    dirPerson1.clear();
    dirPerson1.Name = firstName;
    dirPerson1.insert();
    dirPersonName.clear();
    dirPersonName.FirstName = firstName;
    dirPersonName.Person = dirPerson1.RecId;
    dirpersonName.insert();
    hcmWorker.clear();
    hcmWorker.Person = dirPerson1.RecId;
    hcmWorker.PersonnelNumber = personnelNumber;
    hcmWorker.insert();
    hcmEmployment.clear();
    hcmEmployment.Worker = hcmWorker.RecId;
    hcmEmployment.EmploymentType = employmentType;
    hcmEmployment.ValidFrom = validFrom;
    hcmEmployment.ValidTo = DateTimeUtil::maxValue();
    hcmEmployment.LegalEntity = CompanyInfo::findDataArea(companyName).RecId;
    hcmEmployment.insert();
    info(strFmt('Employee %1 created', hcmWorker.PersonnelNumber));
    insertcount++;
    comtype = cells.item(row+1, 1).value().variantType();
    ttsCommit;
    catch(Exception::Error)
    info(strFmt("Error in row %1", row));
    while(comtype != COMVariantType::VT_EMPTY);
    info(strFmt("%1 Record(s) inserted", insertcount));
    application.quit();
Related
Recommended
