Unbalanced X++ TTSBEGIN/TTSCOMMIT
hi
error while open the Tutorial_Workflowprocesses form in AX 2009
  • It seems there is a been transaction block that was not properly handled. It may pushed the application tts level to 1.
    Is it only happens when you run the workflow processor?
    Write a job to set the tts level to zero.
    if (appl.ttslevel() > 0)
    ttsabort; (edited the typo mistake)
  • In reply to Kranthi:
    Hi kranthi..
    i run this line of code and again same problem facing..every time kranthi not only work flow
    static void ResetTTS(Args _args)
    while (appl.ttsLevel() > 0)
    info(strfmt("Level %1 aborted",appl.ttsLevel()));
    ttsAbort;
  • In reply to AKumar:
    Anil
    Can you explain in detail?
  • Check your code, You may be missed to add ttsbegin or ttcomit;
    When i try to create new PO while running the Tutorial_WorkflowProcessor form and when i press the F5 i am getting above error
    After resetting the ttslevel, have you tried by restarting the client?
    Yes kranthi i restarted the Client
    There should be something wrong in your code. check all the tts blocks are correct in your code.
Related
Recommended
