Warehousing APP username and password
Hello All:
I am trying to login into Dynamics 365 for Operations - Warehousing APP.
I created myself as a worker in D365 operation. In the retail tab.
I tried to use the same password which I found from back end using this SQL query (
Select * from RetailStaffTable RST where NAMEONRECEIPT like '%shan%')
But no luck.
 I also tried logging in as my userid i.e. siyer but unable to log in.
Kindly advice
Shankar J
  • Hello All:
    Senior technical architect in my team found a solution :
    the path to setup Warehouse worker is: Warehouse management > Setup > Worker. Here in this form, you should able to add or reset password for a worker
    Create a new user and set a password and use it here
    and once you are in, you will see this window
    Shankar :)
