Enterprise portal installation issue
Kindly help to solve this problem
while installing Dyn Enterprise portal we got this error
Error:
2017-04-21 18:21:00Z        Warning: Object Server 01:  Internal version mismatch. Microsoft Dynamics AX client from WINAXR3 (6.3.5000.138) tried to attach with 6.3.164.0 revision of kernel
2017-04-21 18:21:00Z        Information: The description for Event ID '110' in Source 'Dynamics .NET Business Connector 6.0' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'6.0: ', 'AxCryptoClient - New encryption key created'
2017-04-21 18:21:00Z        Error: The description for Event ID '110' in Source 'Dynamics .NET Business Connector 6.0' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'6.0: ', 'External component has thrown an exception.
2017-04-21 18:21:00Z       at BCLogon(LOGON_INFO* , SesPblk_t** , Char** )
2017-04-21 18:21:00Z           at AxCore.AxSessionFactory.Logon(BC_PROXY_ACCOUNT_INFO* pBCProxyAccountInfo, String company, String language, String objectServer, String configuration, String aol, String aolCode, String tenant, String* msg, SesPblk_t** ppSesPblk)'
2017-04-21 18:21:00Z        Error: The log on attempt to the server from user DOMAIN\ADMIN failed, when using Dynamics Adapter LogonAs from process w3wp and thread id 13.
Related
Recommended
