Ep installation
I am new in Enterprise Portal (EP) and have to install ep in a whole new environment. I installed Share point 2010 with all prerequisites and then run it's wizard also and created a web site (As per the SP setup).
Now i was trying to install EP for AX 2012 R3 through AX installation wizard but the process finish with a fail log. I checked the log and got these message.
2017-04-18 10:58:07Z Component installation task stopped due to an error. 2017-04-18 10:58:07Z ****************************************************************************************************** 2017-04-18 10:58:07Z ****************************************************************************************************** 2017-04-18 10:58:07Z The service cannot be started, either because it is disabled or because it has no enabled devices associated with it. (Exception from HRESULT: 0x80070422) 2017-04-18 10:58:07Z ****************************************************************************************************** 2017-04-18 10:58:07Z ****************************************************************************************************** 2017-04-18 10:58:07Z System.Runtime.InteropServices.COMException (0x80070422): The service cannot be started, either because it is disabled or because it has no enabled devices associated with it. (Exception from HRESULT: 0x80070422) 2017-04-18 10:58:07Z at WUApiLib.UpdateServiceManagerClass.QueryServiceRegistration(String ServiceID) 2017-04-18 10:58:07Z at Microsoft.Dynamics.Setup.MuApiWrapper.IsMachineAlredyOptedIntoMU() 2017-04-18 10:58:07Z at Microsoft.Dynamics.Setup.Support.SetupQueue.MsiInstallationClass.SearchDownloadInstallMicrosoftUpdates(String executionName) 2017-04-18 10:58:07Z at Microsoft.Dynamics.Setup.Support.SetupQueue.ComponentsInstaller.PerformWork() 2017-04-18 10:58:07Z at Microsoft.Dynamics.Setup.Support.SetupQueue.InstallationClass.DoWork(Object sender, DoWorkEventArgs e) 2017-04-18 10:58:07Z at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument) 2017-04-18 10:58:07Z ****************************************************************************************************** 2017-04-18 10:58:08Z S260FinishedInfo 2017-04-18 10:58:09Z Property RemoveComponents set to: '0'
Help me to understand this log also Provide any Step by Step document from the beginning of EP installation.
Related
Recommended
