Create JV through code
   I just wrote a piece of code to create General Journal voucher
 when i run that code it seems to me ok. but when i go to General Journal form it showing blank field
while i check from back end (in LedgerJournalTrans Table). it showing exact data.
so my question is that why it is not showing in form.
AXVersion AX2012r3 And code is given below
public void importGJVoucher(Filename    _fileName)
    LedgerJournalNameId         journalName;
    CommaIo                     Io;
    str                         column1,column2,column3,column7;
    DimensionDisplayValue       column4,column8;
    Amount                      column5,column6;
    Voucher                     voucher;
    container                   data;
    NumberSeq                   numberseq;
    MainAccountNum              ledgerAccount;
    GeneralJournalAccountEntry  GJAEntry;
    CustAccount                 custAccount;
    VendAccount                 vendAccount;
    LedgerJournalName           ledgerJournalName;
    LedgerJournalTable          ledgerJournalTable;
    LedgerJournalTrans          ledgerJournalTrans,ledgerJournalTrans1;
    DimensionAttributeValueCombination  DAVCombination;
    Io          = new CommaIo(_fileName,'r');
    data        = Io.read();
    journalName = 'JV';
    // Create Journal Header
    ttsBegin;
    LedgerJournalName               = LedgerJournalName::find(journalName);
    LedgerJournalTable.clear();
    ledgerJournalTable.initValue();
    LedgerJournalTable.initFromLedgerJournalName(LedgerJournalName.JournalName);
    LedgerJournalTable.JournalNum   = NumberSeq::newGetNum(LedgerParameters::numRefJournalNum()).num();
    LedgerJournalTable.JournalName  = journalName;
    LedgerJournalTable.JournalType  = LedgerJournalType::Daily;
    voucher                         = NumberSeq::newGetVoucherFromCode(NumberSequenceTable::find(ledgerJournalName.NumberSequenceTable).NumberSequence).voucher();
    LedgerJournalTable.insert();
    while(Io.status() == IO_Status::Ok)
        data    = Io.read();
        column1 = conPeek(data, 1);
        column2 = conPeek(data, 2);
        column3 = conPeek(data, 3);
        column4 = conPeek(data, 4);
        column5 = conPeek(data, 5);
        column6 = conPeek(data, 6);
        column7 = conPeek(data, 7);
        column8 = conPeek(data, 8);
        // Create Journal Line
        LedgerJournalTrans.clear();
        LedgerJournalTrans.initValue();
        LedgerJournalTrans.JournalNum           = ledgerJournalTable.JournalNum;
        LedgerJournalTrans.TransDate            = str2Date(column1,123);//systemDateGet();
        LedgerJournalTrans.AccountType          = LedgerJournalACType::Ledger;
        LedgerJournalTrans.Txt                 = column3;
        select * from DAVCombination
        join ledgerJournalTrans1
        where DAVCombination.RecId          == ledgerJournalTrans1.LedgerDimension
            && DAVCombination.DisplayValue  == column4;
        LedgerJournalTrans.LedgerDimension  = ledgerJournalTrans1.LedgerDimension;
       // ledgerJournalTrans.LedgerDimension      = column4;
        LedgerJournalTrans.Voucher              = voucher;
        LedgerJournalTrans.AmountCurDebit       = column5;
        LedgerJournalTrans.AmountCurCredit      = column6;
        LedgerJournalTrans.OffsetAccountType= LedgerJournalACType::Ledger;
        LedgerJournalTrans.TransactionType  = LedgerTransType::GeneralJournal;
        LedgerJournalTrans.Approved         = NoYes::Yes;
        select * from GJAEntry
        where GJAEntry.LedgerAccount        == column8;
        LedgerJournalTrans.OffsetLedgerDimension    = GJAEntry.LedgerDimension;
        //ledgerJournalTrans.OffsetLedgerDimension    = column8;
        if(LedgerJournalTrans.validateWrite() && column1 != "0")
            info(strFmt("%1,%2",column5,LedgerJournalTrans.AmountCurDebit));
            LedgerJournalTrans.insert();
            ttsCommit;
    info(strFmt(" General Number %1 has been created", LedgerJournalTable.JournalNum));
Pls  help me.
thanks in advance
Related
Recommended
