CIL generation fails on installation
Hello all,
Today i started with a fresh installation of AX 2012 R3 with CU9 slipstream.After installation,when i started with initiallization checklist
1.COMPILE APPLICATION finished with no errors.
2.Compile into .NET framework CIL i got error stating
"CIL Generation.The Given Key was not present in the dictionary  \XppIL   Er:351
             Error when loading the method type PayrollPayStatementTaxLine Method : Insert"
I checked by stopping the AOS and deleted the file in the directory
" C:\Program Files\Microsoft Dynamics AX\60\Server\MicrosoftDynamicsAX\bin\XppIL"
and started the AOS and run a FULL COMPILE.
But could not resolve the error.
Anyone faced this issue and is there any solution to this issue?
Manikandan.
Related
Recommended
