Print Labels from Dynamics AX Retail
I am trying to print Barcode Labels from Dynamics AX Retail. (Retail > Periodic > Barcodes and Labels > Print Product Labels).
The system is giving me error 'No store has been set up.'
  • hi
    if it's not solved yet; you can follow the below steps:
    1- go to retail shared parameters > general > local store : select store number
    2- go to retail shared parameters > labels> Product labels : select which stores that you want to print labels for
    3- go to barcode and labels Product barcode: and select the report name
    4- now the form should open but you will not be able to print label for a product that doesn't have a product label in it's setup
    I suggest to follow this link for more details :
  • go to retail shared Parameter > general > select the store
