This discussion has been locked.
You can no longer post new replies to this discussion. Posts are automatically locked, when no new replies have been made for a long time. If you have a question you can start a new discussion.
error correction please
I got an error ? like this.
Argument "Helpurl" is incompatible with the required type.
Operand Type are not compatible wit the variable name...
this errors appears while creating a date.any other ways of using that..and I need to perform a date...12/12/2013 this is example..
this much be executed in Switch case ..Thanks in advance.
Related
Recommended
