Error while Deploying/Opening Microsoft Dynamics AX 2009 SSRS Reports
I have deployed the Ax 2009 SSRS report successfully. But When opening the report showing the below error message:
An error has occurred during report processing. (rsProcessingAborted
Query execution failed for dataset 'XXXXDS'. (rsErrorExecutingCommand
Exception has been thrown by the target of an invocation.
Dynamics Adapter CallStaticClassMethod failed.
ClrBridgeLoader : fatal error : Microsoft.Dynamics.ClrBridge.dll cannot be loaded. Fatal error: ClrBridge is not loaded. Object 'CLRObject' could not be created
I thing this is the common issue while deploying the report. I also faced this issue many time but forgot the solution.
Please tell me the solution for this issue..........URGENT.
Thank you,
Krishna Kedarisetti
