Running into RPC 1722 issue - Business Connector session - AOS unavailable
Hello, We are running AX 2012 FP with CU2 and AOS became unavailable. The windows event log revealed the following:
The description for Event ID 180 from source Microsoft Dynamics AX cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Microsoft Dynamics AX Business Connector Session 12.
RPC exception 1722 occurred in session 12 process is Ax32.exe thread is 3420(User: Admin, ClientType: GUI)
Source - Application Error:
Faulting application name: Ax32Serv.exe, version: 6.0.947.862, time stamp: 0x4f12cd00
Faulting module name: clr.dll, version: 4.0.30319.18010, time stamp: 0x5038768c
Exception code: 0xc0000005
Fault offset: 0x000000000005479f
Faulting process id: 0xc0c
Faulting application start time: 0x01ce00d233965492
Faulting application path: C:\Program Files\Microsoft Dynamics AX\60\Server\IronAX\Bin\Ax32Serv.exe
Faulting module path: C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll
Report Id: 364101a4-7483-11e2-9401-00155d021d03
Faulting package full name:
Faulting package-relative application ID:
source - .NET Run time
Application: Ax32Serv.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an internal error in the .NET Runtime at IP 000007F894CC479F (000007F894C70000) with exit code 80131506.
Related
Recommended
