This discussion has been locked.
You can no longer post new replies to this discussion. Posts are automatically locked, when no new replies have been made for a long time. If you have a question you can start a new discussion.
fiscal year closing ax 2012
For fiscal year end closing, when i open GL>Periodic>Fiscal Year Close>Open Transactions system will prompt a warning infolog. The message is to turn on a Posting definitions setting in the GL Parameter, below :
"Posting definitions are required for year end general ledger close. Select the 'Use posting definitions checkbox on General ledger parameters.'"
 And i have trun off and remove the Public sector configuration in the system. But, this warning infolog still happened when i open the Open Trasactions Form.
What the impact if i turn off the public sector from the system?
Related
Recommended
