This discussion has been locked.
You can no longer post new replies to this discussion. Posts are automatically locked, when no new replies have been made for a long time. If you have a question you can start a new discussion.
Error
Hi all
I am facing this error wen i open the client machine of my axapta..pls tel me how to resolve this error.
A user session on the server cannot be created.Try To
start the Client again.If the problem continues,contact
the Microsoft Dynamics AX Administrator
Regards
Manjusha.D
  • Hi,
    Go to the client configuration and check weather the server instance is same or not.
    If not create a new configuration in client and change the  port Number and start the service again.
  • check this:
    https://dynamicsaxtechstuff.wordpress.com/2012/10/09/ax-error-a-user-session-on-the-server-could-not-be-created-try-to-start-the-client-again-if-the-problem-continues-contact-ax-administrator/
Related
Recommended
