Item Master Import
Is there any Direct Template for Upload the Item Master Data in to the Release Item List in  AX by using the DMF.
Regards
Vinod P
  • Yes this is one of the supported entities within DIXF as standard and you can create a template from within DIXF.
  • The DIXF entity you need to use is called 'Product'. It will create a Product, and release it to the company which you are in.
Related
Recommended
