Axapta Interview Questions
Dear All,
I have an upcoming Interview  "Axapta developer" the next few weeks,
I have 3+ years of .Net programing i have taking Axapta course for 45 days i have basic understanding of Axapta and reading now
"Inside ms dynamics 2009"
and i have strong Programing skills ,  OOP , analysis skills .. etc .
I kindly request for interview questions that may be asked during interviews.
Can you list out questions or provide links ???
Thank you.
Moreover , Is it important to know functional areas as Fresher ?
Thank you again.
Sakhr
  • Hi,
    Interview questions have already been discussed here.   Also we discussed resources, learning plans for freshers here. Please search for them.
    Regarding your other question, technical freshers not necessarily expected to know functional areas.  A proper training course would be of great help.
    Best wishes,
    Harish Mohanbabu Long way to go before I sleep ..
    Harish Mohanbabu | Blog
  • In reply to Harish Mohanbabu:
    Normal 0 false false false MicrosoftInternetExplorer4
    I am also very interested in this subject, but the reference is very limited. You can share documents as well as experience? Thanks!
    Patric Holier
  • In reply to Patric Holier:
    If you want to get more materials that related to this topic, you can visit: Normal 0 false false false MicrosoftInternetExplorer4 Group interview questions
    Best regards.
    Patric Holier
    Can u give me some Interview question which can be asked in the interview for the Functional consultant.
    I am practicing the Dynamics AX T & L
    HARI
    HARI
  • In reply to HARI:
    I am also searching for Interview questions on Axapta Functional ?? can anyone plz share the questions
    Krisheed Immadi
  • In reply to Krisheed Immadi:
    It's not the way to collect knowledge or enter in ERP. If you really want to be a good functional consultant then prepare yourself for same.
    Ask to those ppl from them you got training they ppl provide you .pdf file it include all study material. Go through that and raise your knowledge.
    Kiran
    Kiran Waghmare
  • Hello Sakhr,
                       Have a look to the link provided below, Hope it will help you.
                       http://krishhdax.blogspot.in/search/label/Interview%20Points
    Pranav
    Pranav | Blog
  • In reply to Pranav:
    Hello I am updating some interview questions . plz go through this....................................................................................................
    Dynamics AX Interview Questions
    Technical:
    1.       What’s new in Dynamics AX 2012
    2.       OOPs concepts
    3.       Definition of AOT elements
    4.       Layers & their usage.
    5.       Differences:
    a.       AX 4.0 & AX 2009
    b.      MorphX & Intellimorph
    c.       RunBase & RunBaseBatch
    d.      Element & this
    e.      COM & .NET Business Connector
    f.        Concurrent user & Named user
    g.       Primary key & Foreign key
    h.      Construct & New methods
    i.         Normal, field fixed & related field fixed relations
    j.        Table & View in AOT
    k.       Auto design & Generated design in reports
    l.         Business connector & External Connector
    m.    VSS & TFS
    n.      Refresh(),reread(),research() & executeQuery()-(http://kashperuk.blogspot.com/2010/03/tutorial-reread-refresh-research.html)
    o.      formDataSource.queryRun().query() & formDataSource.query()-(http://kashperuk.blogspot.com/2010/03/tutorial-reread-refresh-research.html)
    6.       Delete actions & its types
    7.       Table groups & its types
    8.       Creation of PO & SO thru code
    9.       Flow of SSRS report generation in Dynamics AX-
    AX menu item from rich client->Report viewer opens->Issues request to report server-> Report server connects Dynamics AX(.NET BC)->Fetches the data->Return to client
    10.   AOS Load balancer concept/Clustering
    11.   Dynamics AX security hierarchy
    12.   AX 2009 Workflow configuration
    13.   AIF in Dynamics AX 2009
    14.   Web Services concept
    15.   Version Control System in AX 2009
    16.   Reverse Engineering tool
    17.   MS Visio UML(Data & Object),ERD
    18.   Unit test framework
    19.   Visual Form & Report designer
    20.   AX 2009 Debugger concepts
    21.   Cross reference tool
    22.   Document Management
    23.   Print Management
    24.   Types of joins in AX
    25.   Containers and its functions
    26.   Data Crawler
    27.   Intrinsic functions
    28.   Application Hierarchy Tree
    29.   Optimistic Concurrency Control
    30.   Concept of cubes & MDX queries in SQL.
    31.   Integration from .NET
    32.   Caching mechanism in AX
    33.   Events on a form & report
    34.   Purpose of following methods in AX
    a.        Init(),run(),validatewrite(),write(),close(),canClose() etc.
    35.   What is cloud computing? How it is configured in AX?
    Data dictionary
    1.What is an EDT, Base Enum, how can we use array elements of an EDT,
    2.Definition and use of Maps, how AddressMap (with methods) is used in standard AX
    3.What is the difference between Index and Index hint?
    Utility and use of find method.
    4.How many types of data validation methods are written on table level?
    5.How many types of relations are available in Axapta, Explain each of them.
    6.When the recid is generated, what is its utility, what are the different types of Table groups defined on table properties.
    7.Difference between Primary & Cluster index.
    8.How many kind of lookups can be made and how.
    9.How can we utilize field groups in forms
    10.How many types of Delete Actions are there in Standard Ax and define the use of each
    11.If any record is created in table I want to fetch the date & time stamp, how will you do that
    12.What is the function of super()
    Classes
    1. What is an abstract class, what is the utility of an abstract method
    2. Multiple inheritance possible or not, if not how can we overcome that.
    3. What is an interface, Why do we implement it
    4. Do we need to write main method, give reasons
    5. What is difference between new & construct method
    6. What is the utilty of the RunOn property
    7. What is main class used in batch process OR which class will you inherit to make a batch job
    8. How can we make a batch job occur at regular interval
    9. What is the main utility of classes in standard Ax
    10. Which class is called when we create a SO/PO.
    11. What are classes used to write query.
    12. What is a static method, why do we make static methods and where can we write it.
    13. When do we make methods private or protected.Forms
    1. What is the basic structure of a form
    2. Utility of init(), run(), wait() methods
    3. What are different types of Link Types available in a form datasource, justify each of them
    4. Properties of a form datasource
    5. validateWrite() method can be written in form datasource as well as table level, when should we write it in form DS and when in table. Similar in case of write() method
    6. How can we call table level methods from form DS (similar methods)
    7. What is the difference between form init() & DS init()
    8. When a form opens what are the sequential methods called.
    9. Where is the best place to write code to perform filter in a form
    10. What are the different types of menu items available, explain each of them
    11. A action type menu item is attached to a form but in the drop down the menu item is not appearing, what could be the problem
    Reports
    1. What are the two most important methods
    2. When do block the super() method of fetch
    3. Can we make a report from wizard, if yes from where
    4. What is a Programmable Section, how we use it in reports
    5. What is the difference between Auto Design Spec & Generated Design
    6. How can we sort the DS, what facility we can get in by placing fields in Ranges
    7. What is the role of executeSection
    8. What are Queries, how do we use them
    Menu Items
    1. What is the use of Parameter, Enum TypeParameter/Enum Parameter properties of display
    2. Why do we provide Configuration key & Security key
    3. Normally what do we attach in Output
    4. Normally what do we attach in Action
    General Questions
    1. What is difference between select & select firstonly statements
    2. What are the keywords used to access data from "multiple companies" and "one company to another company".
    3. How can we override a lookup
    4. How do the following methods work in a form DS.
    ds.refresh(), ds.research(), ds.reread(), in what situation we should these methods
    5. On closing a form name the methods which are invoked
    6. What are security key/configuration keys, how do we use it in Ax
    7. How can we provide user level/user group level security
    8. What is a virtual company
    9. What is Visual MorphXplorer, what do we do with that?(Reverse engineering tool has replaced Visual MorphXplorer)
    10. What is the function of Application Hierarchy Tree
    11. If you want to monitor the database activity, where can you get that
    12. Where can we find the Label log and what is its utility
    13. What are the tools you will use to upgrade any object
    14. What is the difference between display() and edit() methods, how do we use each
    15. What is the use of System Documentation/Application Developer Documentation/Application Documentation
    Few More Questions on DAX
    1.What are the classes, Tables, Forms and Methods used to post the sales orders.
    2. What are the classes, Tables, Forms and Methods used to post the purchase orders.
    3. What are the classes, Tables, Forms and Methods used to post the Ledgers.
    4. What are the classes, Tables, Forms and Methods used to post the Inventory.
    5. What is the base class to send the on-boad E-mailing.
    6. What are the storage Dimensions?
    7. What are the Item Dimensions?
    8. What is the difference between RunBase and RunBaseBatch?
    9. How do you create a NumberSequence for existing Module and also fro new Module.
    10.What is the difference between Insert and doinsert.
    11.What is the Runbase Stack?
    Venkat
  • In reply to Venkat:
     my sincere advice is be honest.
    in addition to the list check this too.
    http://blogs.msdn.com/b/axinthefield/archive/2011/11/10/interviewing-ax-candidates-what-i-look-for-part-1.aspx
    http://blogs.msdn.com/b/axinthefield/archive/2011/11/17/interviewing-ax-candidates-questions-part-2.aspx
    eswar
Related
