Change BOM Item - Replace Variant
hi,
We have a requirement to change the Bom Item where Item has variant to replace with  a New item Code which don't have any Variant .
To : New Code with out any Variant
Standard AX 2012 R2 , we are able to replace the BOM item with out any problem where From /TO Item code don't have any variant.
Kindly advise how to replace the Item code has Variant  in BOM Line.
Raj
  • Hi Raj,
    From the data you have provided, its very difficult to understand your exact requirement. let hope below workaround/solution best fits your requirement.
    1. Change/update the existing BOM line with new item by manually.
    or
    2. Use Alternate item functionality available on Release product form.
    It would be good if you explain with example.
Related
Recommended
