Quarantine order & quality order
What is the difference between "Quarantine order & quality order"...explain with an example....
  • In my own words... Quarantine order, would be a document that avoids the use of a particular item/batch while it is open, once it is closed, you can use that item batch.
    Quality orders are documents that have a group of quality test so you can make necessary analysis and enter results.
    A quarantine order can have a quality order associated to it, or not.
Related
Recommended
