Error: The path \\xx\\x\x does not exist or is not accessible from an AOS server. Always use a UNC path. Positive Pay
I have done the positive pay Setup just like its mentioned on Microsoft Technet.(https://technet.microsoft.com/en-us/library/dn269119.aspx) When I am checking the log of the Batch job, I am seeing the error: The path \\xx\\x\x does not exist or is not accessible from an AOS server. Always use a UNC path.
I gave the UNC Path like \\servername\folder\x\x\
I have shared this folder with read/write access to me and Administrators.
As its saying not accessible from AOS server, Is there anything else i need to do? Can someone please help. Thanks.
  • I am able to fix this. Provided Service account (on which AOS is running) access to the folder and it worked. Thanks.
Related
Recommended
