Quality order failed-Not visible in Quarantine Orders
We are using AX 2012 R3. I have failed a Quality order, later i wish to clear it, but i am unable to find it in the Quarantine orders
  • Do you want to create a quarantine order if the quality order fails? If so does the 'Quarantine upon validation failure' enabled on Quality association?
  • In reply to Kranthi:
    Hi Kranthi,
    We don't want Quarantine orders to be created if a Quality orders fails
    'Quarantine upon validation failure' is enabled on the popup which is displayed while approving.
    Thanx
    TP
  • In reply to thomphl:
    Then what problem do you have?
    thomphl
    Why cannot you disable it?
    Sorry for the confusion..
    Let me rephrase the case
    We had failed a Quality order, later when we want to make it Pass we are unable to PASS. System throws an error.
    If it was in Quarantine, then i could have passed it. Even i am unable to find it in the Quarantine order.
    Thanx
    TP
    What error you are getting?
Related
Recommended
