Dual write update not happening
I am trying to pass data from F&O to CE via dual write. I have created a custom entity and whenever I am creating a new record it flows into CE, however when updating the same record I am getting an error:
Unable to write data to entity ####.Writes to #### failed with error message Request failed with status code PreconditionFailed and CDS error code : 0x80060892 response message: A record that has the attribute values Field1, Field2 already exists. The entity key Field2 requires that this set of attributes contains unique values. Select unique values and try again...
Note: Field1 & Field2 are part of PK in F&O and CE also Field2 is a lookup in another table which is header. I have checked that data is flowing in CE and also all fields are mapped properly. Can anyone please advice me on how to resolve this issue.
Thanks in advance!
Related
Recommended
