How to access Args inside dialog() in a runbasebatch class?
Main method:
server static void main(Args args)
    VCInstrumentCreateForm   VCInstrumentCreateForm = VCInstrumentCreateForm::construct();
    if (!args || !args.record())
        throw error(strFmt("@SYS29104", classStr(VCInstrumentCreateForm)));
    if (VCInstrumentCreateForm.prompt())
        VCInstrumentCreateForm.run();
Dialog method
- I can get the caption through ARGS inside MAIN, however cannot access it through dialog method
public Object dialog()
    VCInstrumentCreateForm VCInstrumentCreateForm;
    DialogRunbase   dialog= Dialog::newFormnameRunbase(formstr(VCInstrumentCreateForm),this);
    dialog = this.dialogInternal(dialog);
    //PROBLEM HERE
    //dialog.caption("...caption will be coming from an args param...");
    dlgBillingScheduleGrp = dialog.addGroup("Billing Schedule date:");
    dlgStartDate = dialog.addField(extendedTypeStr(TransDate), "Start date:");
    dlgStartDate.value(startDate);
    dlgEndDate = dialog.addField(extendedTypeStr(TransDate), "End date");
    dlgEndDate.value(endDate);
Related
Recommended
