Records created through Code are not Appearing on form. Data is not Visible on form
In D365 F&O I Have one requirement where is need to create cross company data for "forecast Supply" budget.
i have created the data and the data is appearing on SQL also but the same data is not visible on Form. I have checked all the necessary fields and values for mandatory fields are coming correctly. Also the data is getting created on Desired Legal entity but the same data is not coming on form.
Related
Recommended
