Method never returns a value in AX 2012
hi Experts,
I have Created a method In DPclass (I have to show Category ) but it gives following error
"Method  never returns a value"
private str Category(ItemId _itemId)
    ECORESCATEGORY eCORESCATEGORY ;
    INVENTTABLE iNVENTTABLE ;
    EcoResProductCategory  ecoResProductCategory;
    while select * from ECORESCATEGORY
 exists join  iNVENTTABLE
 exists join  ecoResProductCategory
    where  EcoResCategory.RecId == EcoResProductCategory.Category
        &&    INVENTTABLE.PRODUCT  == EcoResProductCategory.PRODUCT
        &&  iNVENTTABLE.ItemId == _itemId
        //info(strFmt("%1's Category ",ECORESCATEGORY.NAME));
    return strFmt (ECORESCATEGORY.NAME);
Please guide me
  • You don't understand yourf own code because you made it difficult to read. Let me rewrite it for you:
    private str category(ItemId _itemId)
        EcoResCategory ecoResCategory;
        InventTable inventTable;
        while select ecoResCategory
    		exists join inventTable
    			where inventTable.ItemId == _itemId
    			where ecoResProductCategory == ecoResCategory.RecId
    			   && ecoResProductCategory.Product == inventTable.Product
    		return ecoResCategory.Name;
    Now you can easily see that there is no return statement for the situation when the query doens't fetch any record. You should either return a value or throw an exception.
    By the way, there is no point using a while loop if you end the method when you find the first record. Therefore you could do this:
    	select firstOnly Name from ecoResCategory
    			   && ecoResProductCategory.Product == inventTable.Product;
Related
Recommended
