How to update the Item variants Color, size, style in Ax 2012
Hello All,
iam facing one issue while updating the item master variants( Color, Size, style) based on product dimension group, the values are not getting  updated facing the below error.
Cannot edit a record in Product masters (EcoResProductMaster).
An update conflict occurred due to another user process deleting the record or changing one or more fields in the record.
below is the code, please help me if any thing wrong in the code
static void Job_VariantsUpdate(Args _args)
EcoResProduct ecoResProduct;
EcoResProductDimensionGroupProduct ecoResProductDimensionGroupProduct;// record
EcoResProductMaster ecoResProductMaster;
EcoResProductDimensionGroup ecoResProductDimensionGroup;
EcoResProductDimensionGroupFldSetup ecoResProductDimensionGroupFldSetup;
EcoResDistinctProductVariant ecoResDistinctProductVariant;
Name name;
// ttsBegin;
//ecoResProductMaster.selectForUpdate(true);
while select ecoResProductMaster
where ecoResProductMaster.DisplayProductNumber == "Item001"
join ecoResProductDimensionGroupProduct
where ecoResProductDimensionGroupProduct.Product == ecoResProductMaster.RecId
where ecoResProductDimensionGroup.RecId == ecoResProductDimensionGroupProduct.ProductDimensionGroup
join ecoResProductDimensionGroupFldSetup
where ecoResProductDimensionGroupFldSetup.ProductDimensionGroup == ecoResProductDimensionGroup.RecId
name = fieldId2pname(tableNum(InventDim), ecoResProductDimensionGroupFldSetup.DimensionFieldId);
if (name == "Size" && ecoResProductDimensionGroupFldSetup.IsActive == NoYes::Yes)
ttsBegin;
ecoResProductMaster.RetailSizeGroupId = "Size";
ecoResProductMaster.update();
ttsCommit;
if (name == "Color" && ecoResProductDimensionGroupFldSetup.IsActive == NoYes::Yes)
ttsBegin;
ecoResProductMaster.RetailColorGroupId ="Color";
ttsCommit;
if (name == "Style" && ecoResProductDimensionGroupFldSetup.IsActive == NoYes::Yes)
ttsBegin;
ecoResProductMaster.RetailStyleGroupId = "Style";
ttsCommit;
info("done");
Related
Recommended
