Packing Slip reports with two designs
Hi Experts,
I have two report designs for packing slip which prints one after the other after packing slip is posted
I want Note Type to display on Report design of Packing slip and Cert to display on CERT Report design
Here is what i hvae done so far
  • Declared boolean isCert in SalesPackingSlipDP class decleration
  • In process report method
if(objContract.parmDocumentTitle() == literalStr("@SYS11549"))
        isCert = false;
    else
        isCert = True;
  • In SetSalesPackingSlipDetailsTmp method
   if ((custFormletterDocument.DocuOnPackingSlip == DocuOnFormular::Line)
             || (custFormletterDocument.DocuOnPackingSlip == DocuOnFormular::All))
                If(isCert)
                    docuRefSearch = DocuRefSearch::newTypeIdAndRestriction(custPackingSlipTrans,"CERT",DocuRestriction::External);
                    salesPackingSlipTmp.Notes                   = Docu::concatDocuRefNotes(docuRefSearch);
                else
                    docuRefSearch = DocuRefSearch::newTypeIdAndRestriction(custPackingSlipTrans,custFormletterDocument.DocuTypePackingSlip,DocuRestriction::External);
The issue is output displays certification type notes in both reports and unable to switch between designs in code
Debugged few times but was unable to get an idea where the designs are switching
Kindly advice
Related
Recommended
