How to create dimension lookup(value and name) with multiselect lookup
HI All,
I need to create a multiselect dimension lookup(Value and name).
i have tried the following but didn't get the solution
1.  Using DimensionvalueLookupHelper class i got both the name and value, but multiselect option was not there
     DimensionValueLookupHelper::lookupDimensionValues(dimensionAttribute,_ctrl)
2. Using SysLookupMultiSelectCtrl and DimensionAttributeValue table i got the multiselect option but didnt have an option to include a method(getname()/getValue())
Query query = new Query();
int mutiSelectTableNum = tablenum(DimensionAttributeValue);
container selectedFields;
query = projectSSRSHelper::Dimension1Lookup(dimensionAttribute);
selectedFields = [mutiSelectTableNum, fieldname2id(mutiSelectTableNum, fieldstr(DimensionAttributeValue, DisplayValue))];
SysLookupMultiSelectCtrl::constructWithQuery(this.dialog().dialogForm().formRun(), dimension1.control(), query, false, selectedFields);
class ProjectSSRSHelper
      public static Query Dimension1Lookup(dimensionAttribute _dimensionAttribute)
         QueryBuildDataSource qbds, qbds_join;
         QueryBuildFieldList qbfl;
         qbds = query.addDataSource(tableNum(DimensionAttributeValue));
         qbds.addRange(fieldNum(DimensionAttributeValue, DimensionAttribute)).value(SysQuery::value(_dimensionAttribute.recid));
         qbfl = qbds.fields();
         qbfl.dynamic(false);
         qbfl.clearFieldList();
        qbfl.addField(FieldNum(DimensionAttributeValue,Displayvalue));
        qbfl.addField(FieldNum(DimensionAttributeValue,DimensionAttribute));// as we dont a have description/name field.
        return query;
is there way to add getname() method of DimensionAttributevalue table as a field list.
can anyone help on this
Related
Recommended
