SysOperation framework doesn't show input parameters
As title, I added my controller to the menuItem and my and i can see the dialog, but when i press ok i get this error:
 controller class:
class ServiceLevelSupplierController extends SysOperationServiceController
    public static void main(Args _args)
        ServiceLevelSupplierController controller = new ServiceLevelSupplierController(classStr(ServiceLevelSupplierController),methodStr(ServiceLevelSupplierService,process),SysOperationExecutionMode::Synchronous);
        controller.parmArgs(_args);
        controller.parmShowDialog(true);
        controller.startOperation();
Contract class:
[DataContractAttribute]
class ServiceLevelSupplierContract
    StartDate                       startDate;
    int                             numberOfMonths;
    str                             packedQuery;
    [DataMemberAttribute("StartDate"),SysOperationDisplayOrderAttribute("1")]
    public StartDate parmStartDate(TransDate    _startDate = startDate)
        startDate = _startDate;
        return startDate;
        DataMemberAttribute('numberOfMonths'),
        SysOperationDisplayOrderAttribute("2")
    public Int parmNumberOfMonths(Int     _numberOfMonths = numberOfMonths)
        numberOfMonths = _numberOfMonths;
        return numberOfMonths;
        DataMemberAttribute,
        AifQueryTypeAttribute('_packedQuery', queryStr(ServiceLevelSupplierQuery))
    public str parmQr(str _packedQuery = packedQuery)
        packedQuery = _packedQuery;
        return packedQuery;
    public void setQuery(Query _query)
        packedQuery = SysOperationHelper::base64Encode(_query.pack());
    public Query getQuery()
        return new Query(SysOperationHelper::base64Decode(PackedQuery));
Service class:
class ServiceLevelSupplierService extends SysOperationServiceBase
    QueryRun                             queryRun;
    int                                  numberOfMonths;
    PurchTable                           purchTable;
    PurchLine                            purchLine;
    VendTable                            vendTable;
    CalculationOfServiceLevel            CalculationOfServiceLevel;
    [SysEntryPointAttribute]
    public void process(ServiceLevelSupplierContract  _contract)
        queryRun = new QueryRun(_contract.getQuery());
        this.getPromptParameters(_contract);
        while (queryRun.next())
            CalculationOfServiceLevel.clear();
            purchTable     = queryRun.get(tableNum(PurchTable));
            purchLine      = queryRun.get(tableNum(PurchLine));
            vendTable      = queryRun.get(tableNum(VendTable));
            CalculationOfServiceLevel.VendAccount = vendTable.AccountNum;
            CalculationOfServiceLevel.insert();
    public void getPromptParameters(ServiceLevelSupplierContract _contract)
        startDate                   = _contract.parmStartDate();
        numberOfMonths              = _contract.parmNumberOfMonths();
what's wrong?
Related
Recommended
