add a specific field of table in a dialog field
i want to add the field TimeZone of table LogisticsAddressCountryRegion to a dialogField
dialogFieldCheck = dialogLocal.addField(attributeStr(LogisticsAddressCountryRegion.TimeZone));
but i'm catching an exception on runtime:
No enum value of types matching logistigsAddressCountryRegion.TimeZone is found
what's wrong?
  • The value of addField() should be a name a data type. What you put there clearly isn't such a thing. If it didn't fail already on LogisticsAddressCountryRegion.TimeZone, the compilation would fail on attributeStr(), because LogisticsAddressCountryRegion.TimeZone isn't a name of an attribute class. And if you provided that, it would make no logical sense, because you want a data type of the field and not an attribute class.
    Remove everything from addField() and put there extendedTypeStr() with the name of the extended data type.
Related
Recommended
