no metadata class defined for data contract object in d365 using Sysoperation
I'm getting this error:
these are my classes:
**CustBalanceController**
    class CustBalanceController extends
    SysOperationServiceController
        public static void main(Args _args)
            CustBalanceController controller = new CustBalanceController(classStr(CustBalanceService),methodStr(CustBalanceService,processData),SysOperationExecutionMode::Synchronous);
            controller.parmArgs(_args);
            controller.startOperation();
**CustBalanceUIBuilder**
    class CustBalanceUIBuilder extends
    SysOperationUIBuilder
        public DialogField dlgCountry;
        public CustBalanceController custBalanceController;
        [Hookable(false)]
        public void build()
            super();
            Dialog dialogLocal = dialog as Dialog;
            dlgCountry = dialogLocal.addField(extendedTypeStr(LogisticsAddressCountryRegionId));
        [Hookable(false)]
        public void postRun()
            super();
        [Hookable(false)]
        public void getFromDialog()
        private CustBalanceController getContract()
            if (custBalanceController == null)
                custBalanceController = this.dataContractObject() as CustBalanceController;
            return custBalanceController;
**CustBalanceDataContract**
    class CustBalanceDataContract implements SysOperationValidatable
        TransDate transDate;
        str packedQuery;
       CustBalanceUIBuilder custBalanceUIBuilder;
        public boolean validate()
            boolean isValid  = true;
            // Perform any validation nessecary.
            if (custBalanceUIBuilder.dlgCountry.value() == "")
                isValid = checkFailed("Scegli un Paese");
            return isValid;
        [DataMemberAttribute,
            AifQueryTypeAttribute
            ('_packedQuery', querystr(CustTable))
            public str parmQuery(str _packedQuery = packedQuery)
            packedQuery = _packedQuery;
            return packedQuery;
        public QueryRun getQuery()
            return  new QueryRun(queryStr(QueryAccountNum));
        public void setQuery(Query _query)
            packedQuery = SysOperationHelper::base64Encode(_query.pack());
**CustBalanceService**
    class CustBalanceService
        LogisticsAddressCountryRegionId countryRegionId;
        SalesTable salesTable;
        [SysEntryPointAttribute]
        public void processData(CustBalanceDataContract _custBalanceDataContract)
            QueryRun queryRun;
            CustTable custTable;
            //create a new queryrun object
            queryRun = new queryRun(_custBalanceDataContract.getQuery());
            // loop all results from the query
            while (queryRun.next())
                salesTable = queryRun.get(tablenum(SalesTable));
                custTable = salesTable.custTable_CustAccount();
                if(custTable.countryRegionId() == countryRegionId)
                    //gli aggiornamenti e le scritture sul db varnno messe dentro ttsbegin e ttscommit
                    ttsBegin;
                    select forUpdate salesTable
                           join Custtable
                             where salesTable.CustAccount == custTable.AccountNum;
                    salesTable.IDNar = custTable.idNar;
                    salesTable.update();
                    ttscommit;
i'm debugging, but i can't figure out. Any helps?
Related
Recommended
