AllowCrossCompany property of an AOT query and still addCompanyRange() is not working
   I am making some changes to the Customer aging report (AR/Reports/Status) . The request is to be able to see the cross company results. I did the below steps and it doesn't seem like adding the companies to the CustAgingReport query.
1) Changed the AllowCrossCompany property of the CustAgingReport to "Yes"
2). With the above change I do see the 'Conpany Range'  tab in the Select query wizard screen when clicked on the Select button is clicked on. I am able to select the companies that I would like to search in
3).  Created a new method in the CustAgingReportDP class to add the selected companies to the query. Below is the code
private void masAddCompanyRange(Query _query)
    container                companies = this.parmQuery().getCompanyRange();
    int                      i;
    DataAreaId               companyLocal;
     QueryBuildDataSource    qbdsLocal;
    //_query.allowCrossCompany(this.parmQuery().allowCrossCompany());
    _query.allowCrossCompany(true);
    qbdsLocal = _query.dataSourceTable(tableNum(CustTable));
    for (i=1;i<=conLen(companies);i++)
        if(conPeek(conPeek(companies, i), 2))
            info(strFmt('1%',conPeek(conPeek(companies,i), 1)));
            companyLocal = conPeek(conPeek(companies,i), 1);
            _query.addCompanyRange(companyLocal);
            //_query.dataSourceName('CustTable').addRange(fieldnum(CustTable,DataAreaId)).value(queryvalue(companyLocal));
    this.parmQuery(_query);
but while debugging when I look at the query text I don't see the range has been added to it. The query looks like this
SELECT * FROM CustTable(CustTable) WHERE ((AccountNum = N'468057' OR AccountNum = N'407178')) AND ((CustGroup = N'20'))
4). I have tried using the line of code
      _query.dataSourceName('CustTable').addRange(fieldnum(CustTable,DataAreaId)).value(queryvalue(companyLocal)); and it does the range but at the end it is throwing the below error
"Filtering at the data source level is not allowed for a cross-company query."
Am I missing something?
Dave
Related
Recommended
