Hi all ,
I have a doubt. I am doing a sales invoice while doing it stores the values in sales table, sales line table through salestablelistpage.
they attached query to the salestablelistpage.
I have select values from the sales table, sales line , hcmworker table but the values are not coming in the report data.
What to do?
I have attached a query to that.. the query contains these 3 tables.
Kindly help me, report is not rendering values.
Thanks & Regards,
Please tell us what kind of data source you're using. Are you directly using a query modeled in AOT or an RDP class?
Did you test the query before trying to use in a report? If not, please do it now.
I was using RPD based class and I have tested. it was only fetching sales id. which i pass a parameter in contract class.
It's not easy to debug RDP reports. You may use my way to debug RDP classes:
metinemreenglish.blogspot.com/.../ax-2012-test-rdp-class-at-axapta-side.html
