Object reference not set to an instance of an object.
I am working on a form which will print to a label. when i hit my print button I get the message  "Object reference not set to an instance of an object."
Below is my code.
[FormControlEventHandler(formControlStr(MJMNeTubingLabel, MJMPrintTubingLabel), FormControlEventType::Clicked)]
public static void MJMPrintTubingLabel_OnClicked(FormControl sender, FormControlEventArgs e)
FormRun formRun = sender.formRun();
FormDataSource formDataSource = sender.formRun().dataSource("SalesTable");
UserInfo userInfo;
MJMLabelFormatSupport UsersLabel;
MJM_ScanFolder ScanFolder;
// this needs to come in as variable
str descript;
//On the TubingRound Label
FormComboBoxControl formTubingLabelFormat = FormRun.design(0).controlName("MJMTubingLabel_TubingLabelFormat");
FormStringControl formSalesId = formRun.design(0).controlName("MJMFinShipLabel_SalesId");
FormStringControl formCustomerRef = formRun.design(0).controlName("MJMFinShipLabel_CustomerRef");//OrderNum
FormStringControl formCageNum = formRun.design(0).controlName("MJMFinShipLabel_CageNum");
FormStringControl formSpoolPartNumber = formRun.design(0).controlName("MJMTubingLabel_MJMSpoolPartNumber");//Manual enter
FormStringControl formExternalItemId = formRun.design(0).controlName("MJMFinShipLabel_ExternalItemId");//PartNum
FormStringControl formLot = FormRun.design(0).controlName("MJMFinShipLabel_Lot");
FormStringControl formAWGSize = FormRun.design(0).controlName("MJMFinShipLabel_AWGSize");
FormStringControl formSalesUnit = FormRun.design(0).controlName("MJMFinShipLabel_SalesUnit");
FormStringControl formReelNum = FormRun.design(0).controlName("MJMFinShipLabel_ReelNum");
FormRealControl formNumPieces = FormRun.design(0).controlName("MJMFinShipLabel_NumPieces");
FormRealControl formLength = FormRun.design(0).controlName("MJMFinShipLabel_Length");
FormRealControl formTopPc = FormRun.design(0).controlName("MJMFinShipLabel_TopPc");
FormDateControl formMFGDate = FormRun.design(0).controlName("MJMFinShipLabel_MFGDate");
FormRealControl formGross = FormRun.design(0).controlName("MJMFinShipLabel_Gross");
FormRealControl formTare = FormRun.design(0).controlName("MJMFinShipLabel_Tare");
FormRealControl formNet = FormRun.design(0).controlName("MJMFinShipLabel_Net");
FormIntControl formNumberOfLabels = FormRun.design(0).controlName("MJMFinShipLabel_NumberOfLabels");
//On the TubingSquare Label
FormStringControl formItemNo = formRun.design(0).controlName("MJMTubingLabel_MJMItemNo");
FormStringControl formOrderNumber = formRun.design(0).controlName("MJMTubingLabel_MJMOrderNumber");
FormStringControl formPartNumber = formRun.design(0).controlName("MJMTubingLabel_MJMPartNumber");
FormStringControl formMfgPartNum = formRun.design(0).controlName("MJMTubingLabel_MJMMFGPartNo");//Manual enter
FormStringControl formBulkWorkOrder = formRun.design(0).controlName("MJMTubingLabel_MJMBulkWorkOrder");
FormStringControl formMfgLotNum = formRun.design(0).controlName("MJMTubingLabel_MJMMFGLotNum");//Manual enter
FormStringControl formRev = FormRun.design(0).controlName("MJMTubingLabel_MJMRevision");
FormStringControl formDescription = FormRun.design(0).controlName("MJMTubingLabel_MJMTubingDescription");
FormStringControl formOutsideDmter = formRun.design(0).controlName("MJMTubingLabel_MJMOutsideDmter");//Manual enter
//FormRealControl formLineNum = FormRun.design(0).controlName("MJMFinShipLabel_LineNum");
//FormStringControl formItemId = formRun.design(0).controlName("MJMFinShipLabel_ItemId");//MfgPartNum
date MFGDate = str2Date(formMFGDate.valueStr(),321);
Str tubingLabel = formTubingLabelFormat.valueStr();
//get the user mane to find format
select * from userInfo
where userInfo.name == xUserInfo::find().name;
//info(strfmt("%1 %2", xUserInfo::find().name, userInfo.id ));
// this is create a unque key for the format file
System.DateTime dateTime = System.DateTime::get_UtcNow();
str utcTimeAsStr = dateTime.ToString('yyyyMdHHmmss');
// find user template and printer
if(tubingLabel == enum2Str(MJMTubingLabelFormat::TubingRoundLabel))
select * from userslabel
where UsersLabel.User == userInfo.id && UsersLabel.LabelFormat == "NTRL";
else if(tubingLabel == enum2Str(MJMTubingLabelFormat::TubingSquareLabel))
where UsersLabel.User == userInfo.id && UsersLabel.LabelFormat == "NTSL";
else if(tubingLabel == enum2Str(MJMTubingLabelFormat::CableSquareLabel))
where UsersLabel.User == userInfo.id && UsersLabel.LabelFormat == "NTCL";
// get location to drop files
select * from ScanFolder
where ScanFolder.MJM_ScanFolder_Name == "Bartender";
// now we create and write the file
System.IO.StreamWriter sw;
InteropPermission perm = new InteropPermission(InteropKind::ClrInterop);
perm.assert();
// file name and location
sw = new System.IO.StreamWriter(strRTrim(ScanFolder.MJM_ScanFolder_Path) + userslabel.User + utcTimeAsStr + ".dat");
// header
sw.WriteLine("%BTW% /f=" + UsersLabel.LabelTemplate + " \" /d=\"%Tigger File Name%\" /PRN=\" " + UsersLabel.LabelPrinter + "\" /r=3 /p /dd /c=" + formNumberOfLabels.valueStr()+ "\"");
sw.WriteLine("%END%");
//variable names
sw.WriteLine("AwgSize, Cage, CustomerPN, SpoolPartNumber, CustomerPo, Lot, Gross, Tare, Net, UOM, ReelNum, NoPcs, Length, TopPiece, SalesOrder, Mfgdate, AwgSizeDesc, CageDesc, CustomerPNDesc, SpoolPartNumberDesc, CustomerPoDesc, LotDesc, GrossDesc, TareDesc, NetDesc, UOMDesc, ReelNumDesc, NoPcsDesc, LengthDesc, TopPieceDesc, SalesOrderDesc, MfgdateDesc");
else if(tubingLabel == enum2Str(MJMTubingLabelFormat::TubingSquareLabel))// Tubing Square Label
sw.WriteLine("OrderNo, ItemNo, PartNum, Rev, MfgLotNo, MfgPartNo, SalesOrder, Description, BulkWorkOrder, Quantity, OrderNoDesc, ItemNoDesc, PartNumDesc, RevDesc, MfgLotDesc, MfgPartDesc, SalesOrderDesc, DescriptionDesc, BulkWorkOrderDesc, QuantityDesc");
else if(tubingLabel == enum2Str(MJMTubingLabelFormat::CableSquareLabel))//Cable Square Label
sw.WriteLine("OrderNo, ItemNo, PartNum, Rev, MfgLotNo, MfgPartNo, SalesOrder, Description, MfgDate, OutsideDmter, Quantity, OrderNoDesc, ItemNoDesc, PartNumDesc, RevDesc, MfgLotDesc, MfgPartDesc, SalesOrderDesc, DescriptionDesc, MfgDateDesc, OutsideDmterDesc, QuantityDesc");
Descript = System.Text.RegularExpressions.Regex::Replace(formDescription.valueStr(), "\"", "");
sw.WriteLine(
"\"" + formAWGSize.valueStr() + "\",\"" +
formCageNum.valueStr() + "\",\"" +
formExternalItemId.valueStr() + "\",\"" +
formSpoolPartNumber.valueStr() + "\",\"" +
formCustomerRef.valueStr() + "\",\"" +
formLot.valueStr() + "\",\"" +
formGross.valueStr() + "\",\"" +
formTare.valueStr() + "\",\"" +
formNet.valueStr() + "\",\"" +
formSalesUnit.valueStr() + "\",\"" +
formReelNum.valueStr() + "\",\"" +
formNumPieces.valueStr() + "\",\"" +
formLength.valueStr() + "\",\"" +
formTopPc.valueStr() + "\",\"" +
formSalesId.valueStr() + "\",\"" +
strFmt("%1/%2/%3",mthOfYr(MfgDate),dayOfMth(MfgDate),Year(MfgDate)) + "\",\"" +
"AWG Size:" + "\",\"" +
"Cage #:" + "\",\"" +
"Customer P/N:" + "\",\"" +
"Part #:" + "\",\"" +
"Customer PO #:" + "\",\"" +
"Lot #:" + "\",\"" +
"Gross:" + "\",\"" +
"Tare:" + "\",\"" +
"NET:" + "\",\"" +
"Unit:" + "\",\"" +
"Reel #:" + "\",\"" +
"No Pcs:" + "\",\"" +
"Length:" + "\",\"" +
"Top Piece:" + "\",\"" +
"Sales Order:" + "\",\"" +
"Mfg Date:" + "\",\"");
sw.Flush();
sw.Close();
sw.Dispose();
sw.WriteLine(
"\"" + formOrderNumber.valueStr() + "\",\"" +
formItemNo.valueStr() + "\",\"" +
formPartNumber.ValueStr() + "\",\"" +
formRev.valueStr() + "\",\"" +
formMfgLotNum.valueStr() + "\",\"" +
formMfgPartNum.valueStr() + "\",\"" +
descript + "\",\"" +
formBulkWorkOrder.valueStr() + "\",\"" +
"Order No:" + "\",\"" +
"Item No:" + "\",\"" +
"Part No:" + "\",\"" +
"Rev:" + "\",\"" +
"MFG Lot No:" + "\",\"" +
"MFG Part No:" + "\",\"" +
"Description:" + "\",\"" +
"Bulk Work Order:" + "\",\"" +
"Quantity:" + "\",\"");
sw.Flush();
sw.Close();
sw.Dispose();
sw.WriteLine(
formMFGDate.valueStr() + "\",\"" +
formOutsideDmter.valueStr() + "\",\"" +
"Rev:" + "\",\"" +
"MFG Date:" + "\",\"" +
"O.D.:" + "\",\"" +
sw.Flush();
sw.Close();
sw.Dispose();
  • have u debug the code written by you  , same where  - form object might not be initialized
  • Which line of code is throwing the error?
    By the way, please use Insert > Insert code to paste source code; it'll make it easier to read.
  • [FormControlEventHandler(formControlStr(MJMNeTubingLabel, MJMPrintTubingLabel), FormControlEventType::Clicked)]
            UserInfo            userInfo;
            str descript;
            perm.assert();
            // header
            //variable names
            sw.WriteLine(
                    "Tare:" + "\",\"" +
                    "NET:" + "\",\"" +
                    "Unit:" + "\",\"" +
                    sw.Flush();
                    sw.Close();
                    sw.Dispose();
            sw.WriteLine(
                    "Rev:" + "\",\"" +
                    sw.Flush();
                    sw.Close();
                    sw.Dispose();
            sw.WriteLine(
                    "Rev:" + "\",\"" +
                    "O.D.:" + "\",\"" +
                    sw.Flush();
                    sw.Close();
                    sw.Dispose();
    This is where the above error occurs
  • It sounds like formTubingLabelFormat is null - please verify it in the debugger. So it seems that MJMTubingLabel_TubingLabelFormat control doesn't exist in the form.
    By the way, you can make your life much easier if you use an extension. Then you'll be able to use the control name directly in code and the compiler will check all names for you.
    Namely, this code:
    can be replaced with this:
    str tubingLabel = mjmTubingLabel_TubingLabelFormat.text();
    Also, if the control is bound to a data source, you should rather use the datasource instead:
    str tubingLabel = mjmTubingLabel.TubingLabelFormat;
    It requires the class to be defined as an extension:
    [ExtensionOf(formStr(MJMNeTubingLabel))]
    final class MyClassName_Extension
    And the event handler mustn't be static:
    public void MJMPrintTubingLabel_OnClicked(FormControl sender, FormControlEventArgs e)
Related
Recommended
