Barcode reading by a barcode scanner
Hi DAX Team,
If I have Table called Location - Having 2 fields - 1st : Location String name  2nd: Location Encode in Barcode Format (Just take it as an example)
Now, once the User scans the Barcode for a particular location, it must display the LOcation string name.
My question here is that is there a possibility that everytime, the barcode is Scanned, the Scanner references the Table in AX: Location(mentioned above) and again displays the value from AX to scanner .
rockkato
Related
Recommended
