Example I have a form with two controls one is button another one is combobox.
Now I want to extend both controls with one extension class.
I have written below code but throwing an error.
[Extensionof(Formcontrolstr(FormName, Button))]
Extensionof(Formcontrolstr(FormName, ComboBox))]
Final Class Class_Extension
But the above code is throwing error like extension of form is duplicated.
Please suggest if anybody have an Idea to extend multiple controls at once.
A single class can't be both a button and a combobox.
What are you trying to achieve?
Depending on what you need, maybe you should create two extensions calling a common logic, or create a form extension instead of control extensions, or something else...
Thanks Martin, I have done it by using the even handler of the control.
