FormDataSource is a in memory temp table - how to go back to its previous state?
   I have a form whose datasource is an inMomory temp table. Initially I load a sibling of a production order. There is a button on the screen upon clicking on it loads all the other siblings of that production order. Now, users want another button when clicked it should back to the original sibling record. Is there a way to go back to previous state of the datasource of the temp table and display the previous data?
version : 2012 R3 CU12
Thanks.
  • What exactly do you mean by a sibling record?
    If you now have two records in the temporary table, you surely can switch between them. But if you changed the data of the record or you destroyed one temporary buffer and created a new one, then the old data don't exist.
Related
Recommended
