Some of the information that you entered is not valid. You must enter valid information before you can continue.
In Dynamics 365 Finance and Operations. I opened Vendors Form and entered Vendor Account Manually and Vend Group ( selected a record from Dropdown) , Entered other required fields. . When i tried to save record it gives me the error "Some of the information that you entered is not valid. You must enter valid information before you can continue.".
When i look at the form, i can see like Vendor Account and VendGroup fields showing some kind of warning as shown below. When i hover my cursor on to the warning symbol, it shows: Last Valid Value: Current Value:
Not sure what it is.
Any idea how to resolve this?
Parents
No Data
Reply
  • So when i am trying to enter vendor details and click Save i am getting two warnings as shown in above post. I thought i removed all customizations that are there in system till today. But when i checked today each model carefully and found a new model which had some Projects. So i tried to delete all of those as much as i can. Then performed Build of all models ( Full compilation as per 2012 terminology). I got some errors and found those customized objects and deleted them. Then Performed Build of all models.
    Finally after Build All models(Application Compile or Full CIL) is completed. Then I tried to create a record in VendTable. Now i didnt get this error and main thing is i didnt see those validation marks for Vendor Account num and Vendor Group fields as i used to get before as shown in above post.
    Conclusion: I removed existing customizations and Performed full application compile(or Build All models) - which resolved this error.
    I am not sure if the issue is resolved because of full compile or because of removing customizations.
Children
No Data
Related
Recommended
