Customers Table field not showing up in data entity json response
I've extended the CustTable and added a column to it, synchronized the db and built the solution. I checked the table via "file browser" to be sure the new column was created and yes it was but when I hit the "/data/Customers" endpoint, I get all the default columns in CustTable but the new column I just added is left out.
How can I go about this?
Related
Recommended
