using SysGlobalcache in a custom class - fails when run in batch
   Below is the original line in an existing custom class that is using
SysGlobalCache globalCache;
boolean isProforma;
isProforma = globalCache.get(curUserId(), 'IsProforma'); // This line returns anytype object and it this case it is returning false when run on the client side as expected.
When running in a batch it is failing on the server and throwing the error. So, I change the line to below to add any2enum conversion run time funcation as below to convert the anytype to boolean.
isProforma = any2enum(globalCache.get(userId, 'IsProforma'));
But it still fails and throwing an error something like below
Microsoft.Dynamics.Ax.Xpp.ErrorException: Exception of type 'Microsoft.Dynamics.Ax.Xpp.ErrorException' was thrown.
at Microsoft.Dynamics.Ax.MSIL.Interop.throwException(Int32 ExceptionValue)
at Microsoft.Dynamics.Ax.MSIL.Interop.ThrowCQLError(IL_CQL_ERR cqlErr)
at Microsoft.Dynamics.Ax.Xpp.CastHelper.ToBoolean(Object _value)
Is there a way to change the line of code to use a different conversion runtime function in the line of code isProforma = any2enum(globalCache.get(userId, 'IsProforma')); to avoid the error?
Thanks.
Dave
Related
Recommended
