Need to store a file stream into a local file path in d365fo
I am fetching a file stream from temp blob storage and I wanted to store it in a local path through code. I have tried the below code, but it is prompting a saveAs dialog whether to save the file to download folder, but I want the file stream to be saved to a specific path automatically through code itself. Please suggest a solution for this issue.
 public static void main(Args _args)
        Str1260 fileUrl;
        container readCon;
        FilePath  tempDir = "C:\\Temp\\DIXF\\file.txt";
        FileUploadTemporaryStorageResult result = File::GetFileFromUser() as FileUploadTemporaryStorageResult;
        if (result && result.getUploadStatus())
            fileUrl = result.getDownloadUrl();
            //info(fileUrl);
            readCon = Binary::constructFromMemoryStream(result.openResult()).getContainer();
           System.IO.StreamReader sReader = new System.IO.StreamReader(result.openResult());
           // Set file contentn string
          str  fileContent = sReader.ReadToEnd();
           // Save file
           File::SendStringAsFileToUser(fileContent, tempDir);
Thanks in Advance,
Gopinath M.
Related
Recommended
