Attach files programmatically using x++
Hi People,
I'm trying to attach files via a web api call (through postman). The file comes in saves the to the docuvalue and docuref tables and expected. but the "Preview" isnt showing. Kindly help...
Here's my code
public void insert()
        DocuRef docuRefTable;
        DocuValue docuValueTable;
        str firstFilePath, firstFileTempPath, firstFileBase64, firstFileName, firstFileExtension;
        int64 _refRecId;
        int _refTableId = 16462;
        BinData binData;
        System.IO.FileStream FileStream ;
        System.Byte[] byte;
        FileIoPermission perm;
        String20 returnMsg;
        str strUTF8Input;
        FileIOPermission permission = new FileIOPermission('', 'r');
        permission.assert();
        firstFileBase64 = this.FirstFileBase64;
        firstFileName = this.FirstFileName;
        firstFileExtension = this.FirstFileExtension;
        _refRecId = str2Int64(this.PointSourceAppRegRecId);
        firstFilePath = System.IO.Path::GetTempPath(); //Get temp path
        //str64 = System.Convert::ToBase64String(_byteArray);//Convert input Byte array in base64 string
        firstFileTempPath = firstFilePath + firstFileName + '.' + firstFileExtension;
        if (_refRecId > 0)
            ttsBegin;
            docuValueTable.clear();
            binData = new binData();
            docuValueTable.File = BinData::loadFromBase64(firstFileBase64);
            docuValueTable.Name = firstFileName;
            docuValueTable.FileName = firstFileName;
            docuValueTable.FileType = firstFileExtension;
            docuValueTable.OriginalFileName = firstFileName + "." + firstFileExtension;
            docuValueTable.Path = firstFileTempPath;
            docuValueTable.insert(); // insert into DB
            if (docuValueTable.RecId)
                docuRefTable.clear();
                docuRefTable.RefRecId = _refRecid;
                docuRefTable.RefTableId = _refTableId;
                docuRefTable.RefCompanyId = curext();
                docuRefTable.Name = firstFileName;
                docuRefTable.TypeId = 'File';
                docuRefTable.ValueRecId = docuValueTable.RecId;
                docuRefTable.insert();
                returnMsg = "Uploaded successfully";
            ttsCommit;
        else
            returnMsg = "Record not exit for the given Id";
        //return returnMsg;
        super();
Related
Recommended
