Data Entity is missing in Import Data Management
I have made an extension of SalesOrderLineEntity and added a customized field from Salesline Datasource to the fields of the entity.
After rebuild, i have tried to use it to Import in Data Management, but the data entity is not showing in the Entity Name drop down in the Import.
It is showing before i have made the modification in the extension.
I have tried to Generate mapping in source, also full Build, but still not showing.
I have also tried to just type it and not go with dropdown and it is working. but not showing in dropdown.
Any help with this issue, thanks.
Related
Recommended
