If I increase the Largest to9 9999999, I also need to increase the Format to PJR_#######
Increasing Largest is OK but when I change Format I get the following error
One or more references using the current number sequence are not sufficiently long to contain numbers from this number sequence.
Does anyone have any ideas?
Thank you
