Lookup on EcoResProductAttributeValue and EcoResTextValue
Hello,
I am trying to create a lookup in D365FO using the EcoResProductAttributeValue view and EcoResTextValue table.  What I want to achieve is a lookup that will receive the lookup control and attribute to look for.  The drop down would then display a list of available values for that attribute.  The problem I am having is that I don't seem to be able to make the link between the EcoResProductAttributeValue and EcoResTextValue. I changed the setup code below to show me the value from EcoResAttributeValue, the TextValue from EcoResTextValue and the RecID from EcoResTextValue.  When I click the drop down, the Value from EcoResAttributeValue is the correct record id in EcoResTextValue, but the EcoResTextValue fields are not correct.  It is like a link doesn't exist even through I created one.  What am I missing in this lookup?
The code for the lookup I have is below.
public static void lookupAttributeGroup(FormStringControl _ctrl, EcoResAttribute _Attribute)
SysTableLookup sysTableLookup = SysTableLookup::newParameters(tablenum(EcoResProductAttributeValue), _ctrl);
Query query = new Query();
QueryBuildDataSource qbds;
QueryBuildDataSource qbdsJoin;
EcoResAttributeType AttribType;
AttribType = EcoResAttributeType::find(_Attribute.AttributeType);
qbds = query.addDataSource(tablenum(EcoResProductAttributeValue));
qbds.addRange(fieldnum(EcoResProductAttributeValue, Attribute)).value(queryValue(_Attribute.RecId));
switch (AttribType.DataType)
case AttributeDataType::Text : QbdsJoin = query.dataSourceTable(tableNum(EcoResProductAttributeValue)).AddDataSource(tableNum(EcoResTextValue));
qbdsJoin.clearLinks();
QbdsJoin.relations(false);
QbdsJoin.joinMode(JoinMode::InnerJoin);
QbdsJoin.FetchMode(QueryFetchMode::One2One);
QbdsJoin.addLink(fieldNum(EcoResProductAttributeValue, Value), fieldNum(EcoResTextValue, RecId));
sysTableLookup.addLookupField(fieldnum(EcoResProductAttributeValue, Value));
sysTableLookup.addLookupfield(fieldnum(EcoResTextValue, TextValue));
sysTableLookup.addLookupField(fieldnum(EcoResTextValue, Recid));
break;
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
Related
Recommended
