Error in rest service like "authorization 301 error" in ax 2012
How to consume the rest api in ax 2012.
I have tried the below code but i getting error like "Authorization 301 error" in response line.
How to resolve the error
static void ODataservice(Args _args)
   System.Net.HttpWebRequest    request;
   System.Net.HttpWebResponse   response;
   CLRObject            clrObj;
   System.Byte[]          bytes;
   System.Text.Encoding      utf8;
   System.IO.Stream        requestStream, responseStream;
   System.IO.StreamReader     streamReader;
   System.Exception        ex;
   System.Net.WebHeaderCollection httpHeader;
   str               byteStr;
   System.Byte[]          byteArray;
   System.IO.Stream        stream;
   System.IO.Stream        dataStream;
   byteStr = strfmt('%1:%2', "USERNAME", "PASSWORD");
   try
     new InteropPermission(InteropKind::ClrInterop).assert();
     httpHeader = new System.Net.WebHeaderCollection();
     clrObj = System.Net.WebRequest::Create(url);
     request = clrObj;
     utf8 = System.Text.Encoding::get_UTF8();
     request.set_KeepAlive(true);
     request.set_ContentType("application/xml");
     byteArray  = utf8.GetBytes(byteStr);
     byteStr   = System.Convert::ToBase64String(byteArray);
     httpHeader.Add("Authorization", 'Basic ' + byteStr);
     request.set_ContentType("text/xml; encoding='utf-8'");
     request.set_Method("POST");
     request.set_Headers(httpHeader);
     requestStream = request.GetRequestStream();
     response = request.GetResponse();
     responseStream = response.GetResponseStream();
     streamReader = new System.IO.StreamReader(responseStream);
     responseXml = streamReader.ReadToEnd();
     info(responseXml);
   catch (Exception::CLRError)
     //bp deviation documented
     ex = CLRInterop::getLastException().GetBaseException();
     error(ex.get_Message());
   requestStream.Close();
   streamReader.Close();
   responseStream.Close();
   response.Close();
Related
Recommended
