Storing value of checkbox in table
Hello,
I need to store the value of a checkbox on the Purchase Order Confirmation form. The check box is custom and I have added it to the PurchEditLines form (displayed there).
So I have a field on the PurchParmUpdate table called CreditReference which has an EDT of NoYes and defaults as no. I am trying to send the new value of the checkbox when it is checked to PurchPurchaseOrderHeader.CreditReference. When I run that confirmation, it shows as a '0'.
Here are some code snippets that I use to run this.
Event Handler Class:
[PostHandlerFor(classStr(PurchPurchaseOrderDP), methodStr(PurchPurchaseOrderDP, processReport))]
    public static void PurchPurchaseOrderDP_Post_processReport(XppPrePostArgs args)
        VendPurchOrderJour              vendPurchOrderJour;
        PurchPurchaseOrderDP            dpInstance = args.getThis() as PurchPurchaseOrderDP;
        PurchPurchaseOrderContract      contract = dpInstance.parmDataContract();
        PurchTable                      purchTable;
        PurchParmUpdate                 purchParmUpdate;
        VendTable                       vendTable;
        HcmWorker                       hcmWorker;
        HcmEmployeeEntity               hcmEmployeeEntity;
        PurchPurchaseOrderHeader        purchPurchaseOrderHeader = dpInstance.getPurchPurchaseOrderHeader();
        vendPurchOrderJour = VendPurchOrderJour::findRecId(dpInstance.parmPurchaseOrderContract().parmRecordId());
        //This if statement works as it should and gives me the correct value in Precision Forms
        if(vendPurchOrderJour.CostCenterDisplay != "")
            ttsbegin;
            while select forupdate * from purchPurchaseOrderHeader
                purchPurchaseOrderHeader.CostCenterDisplay = vendPurchOrderJour.CostCenterDisplay;
                purchPurchaseOrderHeader.write();
            ttscommit;
        //This one will go through the okay as Yes but will go through the
        //purchPurchaseOrderHeader as No in Precision Forms
        if(purchParmUpdate.CreditReference == 1)
            ttsbegin;
                purchPurchaseOrderHeader.CreditReference = purchParmUpdate.CreditReference;
            ttscommit;
    [FormControlEventHandler(formControlStr(PurchEditLines, PurchParmUpdate_CreditReference), FormControlEventType::Modified)]
    public static void PurchParmUpdate_CreditReference_OnModified(FormControl sender, FormControlEventArgs e)
        PurchPurchaseOrderHeader            purchPurchaseOrderHeader;
        FormRun                             fr = sender.formRun();
        FormControlCancelableSuperEventArgs cancelArgs = e as FormControlCancelableSuperEventArgs;
        FormCheckBoxControl                 formCheckboxCredRef = sender as FormCheckBoxControl;
        if(formCheckboxCredRef.checked())
            info("Credit Reference will be printed");
            select * from purchPurchaseOrderHeader
                join purchParmUpdate
                where purchParmUpdate.PurchId_SA == purchPurchaseOrderHeader.PurchId;
            purchParmUpdate.CreditReference = enum2int(NoYes::Yes);
        }else
            info("Credit Reference will not be printed");
            purchParmUpdate.CreditReference = enum2int(NoYes::No);
    [FormControlEventHandler(formControlStr(PurchEditLines, OK), FormControlEventType::Clicked)]
    public static void OK_OnClicked(FormControl sender, FormControlEventArgs e)
        FormRun                     fr = sender.formRun() as FormRun;
        info(enum2Str(purchParmUpdate.CreditReference));
        info(enum2Str(purchPurchaseOrderHeader.CreditReference));
        purchPurchaseOrderHeader.validateWrite();
Contract Extension Class:
[ExtensionOf(classStr(PurchPurchaseOrderContract))]
final class PurchPurchaseOrderContract_Extension
    public CreditReference CreditReference;
    [DataContractAttribute('CreditReference')]
    public boolean parmCreditReference(CreditReference _creditReference = CreditReference)
        CreditReference = _creditReference;
        return CreditReference;
Controller Extension Class:
[ExtensionOf(classStr(PurchPurchaseOrderController))]
final class PurchPurchaseOrderController_Extension
    protected void modifyContract()
        PurchPurchaseOrderContract  purchPurchaseOrderContract = contract as PurchPurchaseOrderContract;
        CreditReference             creditReference;
        next modifyContract();
        creditReference = this.getCreditReference(purchPurchaseOrderHeader.PurchId);
        purchPurchaseOrderContract.parmCreditReference(creditReference);
    public CreditReference getCreditReference(PurchId _purchId)
        if(purchPurchaseOrderHeader.CreditReference == purchParmUpdate.CreditReference)
            info("Header and Update are the same");
        }else
            info("Nope");
        return purchPurchaseOrderHeader.CreditReference;
I also have a CreditReference field on the PurchTable but not sure if I need that.
Why isn't the value being saved in the PurchPurchaseOrderHeader table? I am also looking for advice on what isn't necessary to have in my existing code. For example any classes or methods that I have included to show.
Related
Recommended
