I want to import fixed asset and I also want to import dimension please advice me
thanks for advance
please suggest me
Look at dmf/dixf
thanks for replaying adam
But in my client environment there no dixf so i need to import fixed asset through job
thanks advance
Then you are not running AX2012 or you have configured AX2012 to remove the standard import tools, at which point I would suggest you consider your configuration approach :-) It might be they your user does not have security rights. Data Import/Export Framework is a module like system administration, master planning or general ledger. Standard tool for importing and exporting data, why would you not start there?
AdamRoue said:Standard tool for importing and exporting data, why would you not start there?
thanks for replying adam as we don't have rights to configure in client enivronment normaly we use job only for import and export
please sugguest me for import dimension for fixed asset through job
thanks in advance
Sorry I am not a developer so I could not assist you on a job.
thank you adam
Are you saying that you have permissions to develop and deploy any code but not to use standard features? It makes no sense to me at all.
