I want to retreive all the inventory dimensions which is available on the Production orer -> Trace. It is the tree control it shows the dimenions in a tree structure.
Please any one tell me how can I acheive this?
Any suggestions?
Any other suggestions?
Why do you need other suggestions? It sounds you merely need to complete your logic, not giving everything up.
I can get the details from the tables Inventransorgin, Inventtrans, prodtable and inventdim. But i need two proceeses one for forward and another one for backward. I am debugging the entire process but it is still bit complicated to understand so it would be more helpful if u give any suggestion to proceed on this
Do you have any particular problem? Giving suggestions for an unknown problem isn't easy.
I want to retreive all the trace records for the backward process using X++ code...
