Design a tempTable in class to hold a "matrix" of values
In another post I got to, by the great help of Martin, a solution with a TempTable to hold values.
In post https://dynamicsuser.net/ax/f/developers/96205/memory-not-cleaned-with-struct you can see the discussion
So I want to create a class of a TempTable and then GetSettermethods to get and set the values in the table.
If I'm not wrong I can do that by (assume I created a class of type TempTable named "Commodity"
public real parmOpen(int _id, real _open = 0)
//update value
if(_open != 0)
select forupdate Commodity where Commodity.id == _id;
commodity.open = _open;
commodity.update();
return commodity::find(_id).open;
Wrote it form the top of my head, but its about the concept.
What do you think?
Related
Recommended
