Hello,
I have a requirement to add InventDimCombination.RetailVariantID in various forms across AX.
All these forms/Datasources are related to InventDim table. And the InventDimCombination is also related with InventDim.
How do I write a display method on the various form's data sources, such that I can use the relation with InventDim table to get the Variant ID?
I was trying to do something as shown below, but it doesnt seem to work.
display RetailVariantId Variant(){ InventDim inventDim; InventDimCombination inventDimCombination; PriceDiscAdmTrans priceDiscAdmTrans;
select RetailVariantId from inventDimCombination join InventDim where inventDimCombination.InventDimId == InventDim.InventDimId Join PriceDiscAdmTrans where inventDim.InventDimId == this.InventDimId;
return inventDimCombination.RetailVariantId;}
InventDimId on InventDimCombination is different. It will be build only with product dimension, but not the storage and tracking dimensions.
I think you can use the existing method, \Data Dictionary\Tables\InventDimCombination\Methods\findByInventDim
